Caprice hair edge artifact
I've been having an issue with the Caprice hair where a strange polygon is being generated at the edge of the hair. I'm guessing this has to do with edge interpolation, since changing the setting from sharp edges to sharp edges and corners changes the shape of this polygon, but it makes it worse. The polygon really stands out in renders, even at a distance. Anyone have any experience with something similar? So far i've only seen it on the Caprice hair, both fit to genesis 8 and 8.1 females.
https://www.daz3d.com/caprice-hair-for-genesis-3-and-8-females
  • margravemargrave Posts: 1,822
    That's what happens when you decimate a mesh. The modeling program tries to keep the original shape intact, but sometimes it creates weird polygons like that.
    Go into the Geometry Editor and delete it.
    Worked like a charm, thanks!
