black artifact on render
hello, I use a translator so sorry for the mistakes
as you can see on the render, there is a black "line" above the door, line that I only see when rendering, same thing if I add a roof... anyone have an idea please?
thanks in advance
edit : depending on the angle of the camera it disappears, if it can give you an idea, thanks
Post edited by jesusaramenes on
Which set is that?
I'm not sure what the answer is, the translator translates it as, what set of clothes is this? if that's the question it's "curious dress" from lilflame
No, which set is the corridor from
oh sorry, it's from collective 3d https://www.daz3d.com/collective3d-create-a-room-xpack-3
OK, I have that set, but I am not getting that effect just loading the door uinits. The material on the walls doesn't look like any of the included ones - is it from another set, or an image of your own? Does the image appear to have a black border? I would suspect it does, and the issue is that the tiling value is slightly greater than 1 - tiling doesn't show in preview, and if there is a dark area around the pattern then when the image tiled it would appear in the render. If you like save a copy of the scene without the human character and upload it here, though I think testing it properly may require some other products or files.
the shaders come from this set https://www.daz3d.com/decorator-kit-neutral-shader-presets-for-iray i have just change the color
and I just changed the offset of the tillling for the walls to match, and there is no black border on the image
and as mentioned above it depends on the camera angle
don't bother anymore, I'll redo the walls with blender or change the textures
thanks again and have a nice day
