Help requested: Creation Machine Missing Files
WakakanadaWakakanada Posts: 208
I have installed all my content via DIM on a new computer. It seems to be working, but when I tried to load Creation Machine the error message came up saying the obj. and cr2. file could not be located. Isn't DIM supposed to put things in the right place when directed to the appropriate directories? Everything else loads correctly, and Creation Machine worked on my old computer. Any suggestions? The obj. and cr2 files do not appear to have been downloaded into my new computer.
  • fixmypcmikefixmypcmike Posts: 19,709
    Are those files not installed, or can DS not find them?
    Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • WakakanadaWakakanada Posts: 208
    Here, sorry for the delay, and thanks for you input.
    388 x 169 - 80K
    733 x 205 - 36K
  • TotteTotte Posts: 14,920
    Is that installer two part ? A DS and a PS part? Did you install both?
    Only the DS got installed, but both the DS and Poser files are the same size. [43 and 42 MB]. I thought that usually if they are the same size that you only need the DS file. Should I try downloading both?
    The DS version should be stand-alone, but it looks like the Data files are missing, although strangely after closing that error message, the figure does appear. See if it does work after closing that error message; if it doesn't install the Poser version. I'll report the bug.
    I get a partial load figure with missing forms and textures. Something blocky.
