Marvelous Designer to Daz: Transfer Utility Issue
Hi!
Learned how to make a Vest in Marvelous Designer, followed the tutorial, all the way into Daz. I then did the Transfer Utility, and it goes from Fitting on the Character Just Fine
Image removed
To getting lodged in her Butt...
Image removed
Any ideas where I might've gone wrong? Now the Genesis 8 figure im using has been modified with morphs for a teenage character, so maybe thats the issue? Any help would be much appreciated!
-Sean
I wouldn't say it fits just fine in the first image, because it's clearly clipping through her top. Generally, it's best to model clothes on the base figure and, especially if it's going on top of other clothing, with the other clothes already on.
Please put the Viewport in Smooth Sahded Drastyle, using the sphere icon to the elft of the camera/view picker ("Perspective View") at top-right.
As Gordig says, the model has to line up with the figure as imported - it looks as if you had to apply transforms, or the figure you are using is scaled.
Yep, thats was the Issue, took some finaggling and calling a friend who uses this stuff for ESPN promo shots and we got it to work
