Easy Shape Master, Growing Up bundle and Killer Legs 2.0, do they work with G8.1?
BlueFingers
I'm interested in Zev0's Growing Up bundle and Easy Shape Master of SF-Design to add some variety in the characters I use, and I'm assuming these products work with morphs which would make them usable with G8.1. However the description doesn't say so, but do they it work with G8.1?
Post edited by BlueFingers on
I have not had difficulties applying Genesis 8 morphs to Genesis 8.1, including Zev0's Growing Up. I don't have that particular product from SF-D, so I cannot vouch for it... but I don't see why it would not work.
Genesis 8 expressions have some issues that require manual intervention.
Thanks! I figured I could use them with 8.1 but not having that explicitly stated in the description kind of threw me of. I read on the forum for instance that Killer Legs 2.0 did not work with 8.1 for some reason, if I remember correctly, so wasn't sure anymore.
@BlueFingers, can you elaborate on the issue of Killer Legs 2.0 with Genesis 8.1 or at least direct me to the forum discussion about the problem? As I have modeled my main female cast using this asset, it would be a massive issue if I finally decided to upgrade my DAZ and start using 8.1.
I've had a look if I could find the thread I seem to remember, but could't find it, perhaps I was wrong. I've added Killer Legs 2.0 to the thread-title so we maybe someone can shed a light on it.
But if you have the Killer Legs product and the correct Daz Studio version, you could check if it works on a G8.1. base figure I guess. I would be interested what you find out.
I am still on 4.14, as 4.15 was too unstable for my taste. However, I was pondering to upgrade now, as the general 4.16 release seems to be more stable now. But when I cannot use Killer Legs 2.0 anymore, I will stay on 4.14 and ignore 8.1 a bit longer. Anyway, I would only transform my modeled 8.0 chars to 8.1 without using any official 8.1 figures as they all look too cartoonish for my taste.
Using 4.15 and G8.1 the leg morphs work for me.
This is how you create unnecessary confusion... No thread to show, don't remember what the problem was and if it turned out to be a user error (more than likely).
Only, hierarcial materials/poses, some scripts and shells/grafts have had problems working on G8.1, but otherwise everything made for G8 works or can be made to work (G8 expressions) on G8.1
I only asked because it was not clear in the product desciption. Some products have the the descripition updated with 8.1 compatibility, some haven't. That left me confused and I did not have any other information to go on besides a mental note, I tried my best to find the thread I seemed to remember but couldn't. I really don't seem the harm of asking for help on the forum in such a case.
Anyway, thanks for the info.
The product descriptions are known to be inaccurate.
Killer Legs 2.0 works well for me on G8 and G8.1, as do the "standard" DAZ morphs and all PA character morphs.
Thank you all for your comments. It seems I will try my luck with 4.16 sometime in the holidays.
I can't get Killer Legs 2.0 to work on G8 (not even tried G8.1). I have all the parameter sliders but they don't move - I can't slide them. I'm sure it worked when I bought the product so I must have changed something or DAZ changed something in the meantime.
I don't have the product, but is there a master slider that you need to turn up to activate the other sliders, like with Toon Generations?
Ah right - so there is. But now I see that I might be looking at the wrong set of sliders. Firstly, the master controller is called !Leg Bend Controller and setting that to 100% enables some of the other sliders. Secondly, I have realised that I am in the Pose Controls > Legs parameters and not the Actor > Legs section. So those posecontrols migh be part of a different package or even DAZ defaults.
The Killer Legs parameters appear to be in the Actor > Legs List:
I think "Bend Controller" is part of Zev0's Bend Control.
I'm pretty sure I don't have Killer Legs.
Yeah, that makes sense. I was looking at the wrong parameters
