Adding to Cart…
could be that I have used the poser files :)
It's a very nice set but it takes a very long time to load in Poser 10. I tried it in Poser 8 and it loads pretty quickly. I am trying to separate the four buildings into four separate figure files only it takes a long time to save those to the library in Poser. Poser 8 has locked up four times when trying to do so. Saving to a file isn't a problem.
I was hoping this set would have been broken up into four separate buildings instead of all in one.
Missed this one when it came out. Wish listed it, will pick it up on suitable occasion. It does look great.
have used the landscape and textures for this image and some props of the motel set + some grass from Andrey Pestryakov the container by Predatron (could used the one by Ness Period Production which I also have but I needed a smaller one) and some props of the trash stash also by Predatron. Clothes are by 3D-Age (Top) and Rhiannon (Jeanz) and Hitman47 (shoes) Hair is by Ali (Hair 083)
base texture of Dixies Skin is Natasha Elite Skin fixed by me (some tatoos and tan lines and some little spots here and there, not all you can see in this image). Clouds are from Ultimo Paradiso by AM (Used just the cloud-dome on a pale blue backround)
Lighting by AoA one Distand and one Ambient.
You'll need a creepy looking house for the hill.
Cheers,
Alex.
Hey Cosmo, long time since I seen you post something, I always like your artwork!
Found this in a folder while I was doing some LuxRender renders for my next environment. I can't remember when this got rendered, probably early in the beginning of the year, though it does look a little grainy, could have probably let it bake a little longer. Anyway, no point wasting an image.
Hi, had and have much to do so not so much time right now to make really good renders :) but I hope I will have bit more time soon :)
If you have seen, I have you used the base ground texture also for the side hills :) gives a really good effect of criss-cross rally tracks :)
