Animate lite work field
My 3D Spin
Hi
I have a problem with the work field of Ani mate lite. I cant figure out how to move screens so that i
can see the propertises and the Aniblocks in the animate tab. Is their any way to reset the Animate lite?
I have an aniblock there. But i cant see it!
I have attached a print screen!
Post edited by My 3D Spin on
You have to have a figure selected.
I had a figure selected but it still looks the same!?
When a figure is selected it will be mentioned in various places.
Also I noticed that you need to Activate your copy of Windows ... THAT can cause all kinds of issues as eventually many programs will not work as expected ;-)
It has nothing to do with Windows. Animate Lite worked fine for many years until a few days ago.
i bought some new Aniblocks. when i loaded one of them it was so long over 1000 frames it
stretched the whole field and i couldent even see the block. and you know that loading an Aniblock
you need to have a figure selected. So i need to reset Animate lite somehow!
Okay, other ideas would be to close the pane and open it again. Or change the D/S layout to something else, then switch it back. That step has helped many goofy panes get back into place.
Thank you Catherine. Switching Layouts actually worked. My animate pane is now normal!!
You're welcome, I'm happy to hear that it's working again :-)
