dForce Magnets working... Sorta...
I finally got dForce Magnets working. Had to set Frames to Simulate to Animated (Custom) not Animate (Use Timeline Play Range) as so many videos I watched stated.
When set to Animate (Use Timeline Play Range) and I clicked on Simulate the Timeline nor the magnets moved ergo neither did the material. Tried Animated (Custom) and then it all worked. But then later it worked with (Use Timeline Play Range) too.
But then all was lost, I suffered a cataclysmic force of the Universe known as a dForce explosion... smiley I know this can happen when using the magnets on a non dForce item.
  • What were you trying to do with the magnets?
  • frank0314frank0314 Posts: 14,788
    Can you please use the clay texture on the figure for any further images? It is very close to violating the nudity rule.
    LOL!
