New release PoseRecorder needs better product description!
124»
  • AscaniaAscania Posts: 1,855
    his x said:
    Tugpsx said:
    Ok so I just bought PoseRecorder and it doesnt load on my Windows 10 system
    Getting the below error when i try to launch the application.
    FWIW, I've recently read that it requires an RTX video card to function. I've got a GTX now. When I get some cash for an RTX I'm going to try it out. It's the only one around that doesn't require an iPhone.
    It doesn't. It works just fine on non-NVidia hardware here.
  • it eventually worked on my Win7 with only integrated intel graphics
  • wolf359wolf359 Posts: 3,949
    I recently did a video review of most of the major lipsync
    options for Daz studio( except the Iphone based "face Mojo").
    I only have intel UHD graphics ( No discreet GPU)
    and I run Pose recorder just fine.
  • I just started playing around with this tonight and I'm really impressed. Once you figure out the best settings for video, it works great. (I just convert iphone 720p mov clip to mp4 using the 1080pfast30 preset in Handbrake and I've had no problems). Also clean up the animation by clearing the animation on the eyes after applying the animation to the figure if they go wonky, which seems a common problem. If you're going for a drunk look, the crazy eyes can be a plus though.
  • EurocoinEurocoin Posts: 302
    After almost literally banging my head on the wall, as I only got the "No frames with sufficent quality found" error or Poserecorder just shut itself down without doing anything, I realized something, you have to run Poserecorder as an administrator it to work.
  • I just bought this thinking that I could use it for my videos and short gifs. My initial thoughts are that this product needs a lot of work before it was released, but here we are. In any case,I did initally use my webcam, cause I didn't feel like having to transfer it from google drive each time I wanted to use it. Big mistake, they animations came out terribly. All the facial expressions are so exaggerated and there's so much head movement. I thought that maybe I needed to try it on my phone and get some good lighting in there. So I opened up my blinds and then tried it on my LG Stylo 6. And the results were only slightly better. The eye movement was actually spot on, it looks really good in the eyes. But everything else looks awful still. It's still exaggerating all my mouth movements and cheek movements, doesn't look a whole lot like the promotional videos. I decided to do some test and this is what I came up with thus far -
    1. Do no use the webam, it just won't work. Not sure why, but t just won't.
    2. Upper face movements are great. The eyebrows and eyes are the best. The cheeks and the nose could use a little work.
    3. Doing it too far away does make the mouth movements worse.
    4. I tried ddoing on much closer up, and now it just crashes.
    I agree with most of the comments here that there should be an official thread on this. I'll open up a support thread on this in the technical forum and give the creator a quick message, see if that gets me anywhere. If I can't get this figured out in a couple days (by couple I mean like a week or 2) then I'll ask for a refund at that point. It's a great idea, just could have been executed better.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,606
    I have little luck on my own crooked face with half my front teeth missing
    webcam is terrible but it only does 10FPS apparently
    Videos of other people work reasonably well
  • I've just bought this program and I get a error telling me the program can't download assits and that I should check my internet connection. My connection is fine so I have no idea what's going on. Anyone else having this problem?
  • Think I've found the issue. Laptop runs windows 7 and this program seems to only work for windows 10.
  • It looks like everybody's struggling for lack of proper operating instructions. All I see is "See how easy it is!" I'm looking for somebody to figure out how to use it and then tell all.
  • FirstBastionFirstBastion Posts: 8,056
    edited May 2022
    Answered.
  • mac options for lip sync or facial mocap
  • dshielddshield Posts: 57
    Hi, I bought Poserecorder a while ago with big plans, but only trying to use it now and I find I cant even download it from Daz.
    I'm guessing its something simple I'm missing but $30 is a lot to just write off without even asking for help trying it.
    Any clues would be welcome.
    Thanks.  D
    edited May 2023
    been a while but it downloads additional content from online after installing
    has a zip as well as install manager if that's not working
    https://www.daz3d.com/downloader/customer/files#prod_82905
    should be here
    edited May 2023
    should be here
    Thank You Wendy!!  :)
