strange reflection
hello! i'm trying to reproduce an effect like on the attached picture, but i can't get those "diffracted" reflections at all... thanks for an idea!!!
Diffraction in reflectance is caused by IOR. Not sure the effect is visible without caustic (caustic should be set much higher than the default 1000).
see this article https://www.chaosgroup.com/blog/understanding-glossy-fresnel (different software, but the physic principles are there)
You can try to set different value in IOR, set fresnel effet to 100% and see if it changes something.
Would adding blurry reflections get you the effect you're looking for?
