Missing Files - Runtime - Can't use a content I just bought :(
Hey there!
I'm new to Daz, I just bought two items today: hair and a dress, but the hair it's not working because it says that some files are missing. I actually installed directly to the download option here in the website wich installs automatic, then I decided to do it own my on to see if the problem was that (manually). This is the error I receive for the hair: (the dress is working fine)
Then after it says the error this is how it looks like (It does have compabilitie to G3 too, but I clicked on the normal one):
I did read a couple of articles about how to install manually but unfortunetly I wasn't able to success :( I did open one of Daz content like a default hair for example and check where it was located and then added my bought hair to similar folder, but still not able to success.
I've read the two content before buying and they're both for Genesis 8, you can check them here: Dress & Hair
So I ended up uninstalling the whole program and also using a software that searches for files that the uninstall still leaves there, called Revo, and then I've installed all over again and still not working. I did install from DIM, I did try to install from Daz Central too.
Well the hair requires these: https://www.daz3d.com/dolly-changeable-hair-for-genesis-8-female-s, https://www.daz3d.com/dolly-changeable-hair-for-genesis-3-female-s. Do you own those?
