Is it possible to geograft one figure onto another figure?
So, let's say, I get the verticies and edges to line up, could I say get a head of one figure to graft onto the neck of another figure?
Only if the zeroed figures lined up, but yes if you are absolutely sure the edge vertices match and you have moved the head to align with the body (or vice versa) that would be doable in principle. You would not be able to distribute the results, of course, but you could render them or use them in a game subject to the terms of the licenses for both figures.
This is for a personal project, I don't plan to publish the final asset.
As for changing the figure, I do alter the zero pose significantly, how would I go about baking in the new rotations?
He just means that the figures s would need to be zeroed in order to create the graft. Once you've made the graft, you should be able to pose the figure however you wish.
