bending steel
efron_24
For our super hero's
Can we have some massive steel and such products that super hero's can use for bending and de forming with their pure strength
efron_24
You could ask your superheroes to make do with a cube promitive, with several divisions, strateched with scaling and then bent with a dForm.
It is possible to do yourself. Bending of a simply supported beam:
For steel, using units of mm, E = 207 x 10^3. The second moment of area, I, may be calculated using widely available formulae. For a rectangular section I = width x depth^3/12
Regards,
Richard
I imagine it was more along this.
yes felis.. thanks .. how does one do that with dAZ
You would need to rig it with a skeleton.
I created the steel bar in blender.
Richard suggested that you might do it with a primitive with enough divisions and some D-formers. That might worh, but I found that too cluncy.
if you don't want to use an external modeling app, the quickest way would be a dformer. Create a primitive from the create menu, then add a dformer to it and play with the settings
Must admit I was pulling a leg there and didn't expect the formulae to be used... Those formulae were how I created the realistic deflections to go with the Parallel Bars prop I did over on Rendo (Flex visible here: https://www.renderosity.com/freestuff/items/89683/g8m-parallel-bars-poses-06-to-10) and I used a spreadsheet to calculate 35 sets of deflections for each of 10 different morphs, then applied them to the original bars model (in a 3D modeller I wrote in C++ from scratch). As a result of using the real formulae with real stiffness & flex properties on the wooden bars, the bars look moderately realistic.
I think I'd use a dFormer if staying within DS, but I don't think I would stay in DS. There are much better tools to use. If I could, I'd use blender. As I can't use Blender on my machine due to AV software getting hysterical & I can't get on with Hexagon, I tend to use SolidWorks & a translator I wrote to go from STL to OBJ, then specify surfaces in my modeller & texture map in 'UV Mapper'.
Regards,
Richard
thanks.. will search for dformer... It will be in the menu I think ?
For round or square section steel bars, you could use one of these freebies: https://sites.google.com/site/mcasualsdazscripts/flexithings
