From which character is this skin?
Hey guys, does anyone know from which character is this skin from? It's hard to find especially that the vendor is using this skin mat on different characters.
He using it here:
https://www.daz3d.com/sunny-days-poses-for-genesis-81-female
And also here (middle girl):
https://www.daz3d.com/sunny-days-outfit-textures-for-genesis-81-female
I think that's the same skin but the character is different. If anyone knows from where is this skin I would be grateful. Thanks!
  • QuixotryQuixotry Posts: 919
    That PA has a product called Makeup Artist Essentials LIE Poses and Expressions that seems to be the source of the freckles on that model. I would say that the base texture looks fairly unidentifiable aside from the freckling on the face. It's very smooth and there aren't any other obvious identifying marks. It looks as if those characters might have fibermesh eyebrows, so I'm not sure using the brows as an identifier would help much. You could try using any skin with a similar tanned/bronze tone and use that LIE product to add that freckle pattern to the face.
    If I was trying to duplicate that particular skin, I would probably lean towards FWSA Taia's texture as a starting place. Keep in mind that lighting and surface settings can also affect the look of a character's skin. Different lighting situations can make skin look paler or darker/more or less saturated very easily. FWSA Taia HD, Twosret 8, Lavonne HD, Malia for Celani 8, P3D Melanie HD, RY Felina, or Ziplha HD look like potential options. If you have any of those characters already, you could play around with lights and settings a bit to see how it looks.
    Thank you for your reply! Yes, the skin is very clean without any marks to identify it, Taia's skin seems very similar but that's not in because you can clearly see that she has body marks around her belly button and the desired skin didn't have any marks.
    He obviously bumped the spectacular level and maybe translucency too.
    In the pictures in this product, I think that all girls have the same skin just with different translucency:
  • It's not the skin you're looking for, but if you want a attractive tanned and freckled skin for G8F, I'd suggest this
    https://www.daz3d.com/maliah-for-genesis-3-female
