Confinement Corridor & Cell
in The Commons
I find myself in need of a small corridor with rooms leading off - these look like they could work (with a little retexturing - no confining is planned!). Does anyone know if they are actually designed to work together, eg. do they line up and 'snap' together? From the looks of the promos I hope that it'd be possible to slot the rooms in along the corridor.
If not, can anyone suggest another product?
Thanks!
The rooms don't quite stack to line up with the doors, although removing the redundant wall and door from the room, and scaling it down a bit (~90%), lines them up adequately. Or, just let them overlap, so that the outside wall of one is the inside wall of the other. You might need to move the sink a little, if you keep it. It could have been planned better, but you can only be in one room at a time.
There are several Sci-Fi themed construction kits, several individual Medieval stone and lumber rooms and corridors, residential walls (Create-a-Room series), depending on what you are aiming for.
https://www.daz3d.com/fg-abandoned-mental-hospital
Why does that not surprise me?
Thank you both very much for the suggestions. I think I'm going to set myself a project and build a set specific to my needs. I just hope I remember why I'm building it when I'm done :)
Some of the old West Park stuff might also fit the theme, with both "old, abandoned" and "shiny new" textures, some of them already updated and converted for Iray.
Uh? I don't think they usually did executions in asylums. ECT should be done on a bed with eletrodes at the temples staps and some wicked electronic cabinets. Check out "One Flew Over the Cucoos Nest"
