Missing Files, over & over again: Genesis 8 Starter Essentials
Often when re-opening scene files I get a message that there are missing files. Those files are always Genesis 8 Starter Essentials. I re-install the product as directed, and re-save the scene. But days later I'll re-open it and get the same message. This happens with multiple files. What's happening and how do I fix this?
Thanks
Help -> Troubleshooting -> View Log File.
Post the relevant parts.
Sorry but I don't understand your reply. Are you saying I left out relevant info (if so: what info?), or included unnecessary, irrelevant info?
Oops, missed the top line. Response below.
I'll have to try that next time it happens. Not sure I could find it now.
If we don't know what the errors you're getting say, then we can't really help you fix them. We need details from your log file or the exact wording of the error messages.
If you're not doing anything else, you've probably got a drive getting ready to fail.
I'd recommend running check disk, or another disk utility to make sure it's not that.
Good thought, but the drive is fine.
If the disk doesn't fail diagnostics, then you've either got malware, an o.s. bug, or a much much bigger problem.
Are the "missing" files on the disk or are they actually missing?
Disk problems and malware would be at the end of my list for things to check.
Missing files are all about the way they have been installed, how did you install them and did you also install them inside DS?
