Ultimate PBR skin manager
Looking at the PDF, this software is probably over head... But I'm simply trying to achieve glistening skin. I bought Ultimate PBR skin manager, but don't see how to even load it. I've looked thriugh the PDF and it shows the menus where it's loaded, but doesn't say how to do it. I see scripts, but get errors when double-clicking them.... Any help would be appreciated.
How did you install? Scripts are often not written in a way that is compatible with installing through Daz Studio itself, so if that is what you did it may be worth uninstalling and installing through Daz Central or Daz Install Manager instead.
I installed through Daz Central, so everything should be there. Where do you load it from? I see it in my PRODUCTS under "U." it has a script, but i st an error when I apply it. Do I apply it to the model, the texture? I see no menu windows when I use it. The instructions say nothing as to where it is or how to apply it. How doI get ahold of D3Ciditimes? I see no e-mail link or a place for questions.
What error do you get?
Something like the model is not PBR compatible or something..... HOW do you get to the menus?
if you use 3rd party surfaces or even the 1.7 or 2.0 Nvidia material presets you will get a compatibility error. The default Iray settings with DS will work, they are essentially the same list of parameters but with adjustments for the desired result, the other materials may be compiled completely differently and the manager does not like those.
