feature request: "show in mapped folder" as scene tab right-click option
Say I'm somewhere else in content lib and want to change a texture on an item or similar, finding it again in the content libs after wandering elsewhere can be tedious.
If it has (correct) metadata it's materials should show in Smart Content when it is selected, if Filter By Context is on.
This works by matching the Scene ID of the item with a compatibility base, and then filtering to show only the items thata re compatible with that in Samrt Content and other filtered by metadata views (e.g. the various Presets tabs in settings panes). DS doesn't track the exact file used to load the item - it might have come in via a preset, or via a saved scene, for example so that would not be unambiguous.
