Copy and paste frames in an animation
Hi there,
I've been making animations over say 60 frames where the same action is repeated a number of times. Up until now I've had to do the same work over and over again. Is there a way that I can copy the frames from one set of frames (the original action) and paste them into the frames where the other actions need to be?
I create my animations using the Timeline. I use the other tab (animate Lite) just for adding and removing frames.
You can copy-and-paste via right-click, but in the past the results have not always been correct. at least in the General Release. You can also save a Pose preset for the target range and properties, then aply it at each of the desired times.
Why are you using AniMate Lite to add frames? It is possible to adjust the total number of frames and play range in the Timeline itself
