moving file location
in New Users
I have my runtime texture folders on my C Drive can it be moved to another Drive.
If so ,what are the steps to do this !
How did you install your content?
through daz central, my texture file is 32 gibytes and my data file is about the same but I don't want to mess with it.
I have new Dim and daz central installed , i also used to instal manually and all these files went into c daz3d/ studio/ my librarys.
But most of those installed into daz by by daz central went to C/daz3d/ Applications/ Data / daz3d/ my Daz3d Library.
There is no need to have both DIM and Central and DIM is the better of the two.
Ok ,Can the Daz DIM redirect file to another drive?
In the Advanced Settings (click the gear icon) you can specifiy where you want to place thebisntalled cotnent, applications, downloads, and other things - DIM is very customisable. You do then need to tell Daz Studio where you placed the files, you can do that by downloading http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start using the link above the code and then dragging the file into the Daz Studio Viewport to run it.
Thanks Richard is this the file I should download and install on daz viewport
Link removed
Yes, but please don't post direct links to the files in the Samples pages.
