Daz Studio Pro 4.20[.0.x] - NVIDIA Iray
rbtwhiz
When a new build of Daz Studio includes a new version of the NVIDIA Iray renderer, the new build of the renderer comes with its own set of bug fixes, new features, adjustments to existing features, etc. Since the release of Daz Studio that followed the initial introduction of NVIDIA Iray in Daz Studio (4.8 - initial introduction, 4.9 - following release), a list of its changes have typically been made available in the posts that immediately follow the announcement. In many cases, while the information contained within the posts was/is useful to those that want/need it, it seemed to go unread by many. This same information would also then be reposted when a Public Build was eventually promoted to General Release.
To address some of these issues and bring more visibility to the changes for those who want/need it, we now split these posts off into their own thread. A separate discussion thread will remain available (linked below), but the thread itself will be closed for comment so as to avoid the information being buried by the discussion and to provide notification through regular features of the forum software.
*Note: The entries below come directly from the NVIDIA Iray release notes. Some entries, such as the mention of Iray Realtime, Linux, etc, currently have no bearing on Daz Studio itself but are included for completeness.
Public Build (Beta) Threads:
- 4.20.0.17 (April 21, 2022)
- 4.20.0.12 (April 8, 2022)
- 4.20.0.11 (March 25, 2022)
- 4.20.0.8 (March 17, 2022)
- 4.20.0.6 (March 11, 2022)
- 4.20.0.5 (March 9, 2022)
- 4.20.0.4 (March 3, 2022)
- 4.20.0.3 (February 24, 2022)
- 4.20.0.2 (February 17, 2022)
- 4.16.1.47 (February 14, 2022)
- 4.16.1.43 (February 4, 2022)
- 4.16.1.40 (January 31, 2022)
- 4.16.1.34 (January 21, 2022)
- 4.16.1.31 (January 14, 2022)
- 4.16.1.21 (December 22, 2021)
- 4.16.1.17 (December 17, 2021)
- 4.16.1.6 (December 1, 2021)
- 4.16.1.2 (November 22, 2021)
- 4.15.1.96 (November 12, 2021)
- 4.15.1.91 (November 3, 2021)
- 4.15.1.84 (October 29, 2021)
- 4.15.1.72 (October 7, 2021)
General Release Thread:
- 4.20.0.17 (April 29, 2022)
- 4.20.0.2 (February 18, 2022)
Previous Thread:
Iray 2021.0.0 beta, build 344800.351
Known Issues and Restrictions
Added and Changed Features
The new interface can be obtained from IMdl_factory::create_module_builder(). See also the new example_mdl example. The method IMdl_factory::create_variants() is deprecated and still available if MI_NEURAYLIB_DEPRECATED_12_0 is defined.
Reduced lock scope during MDL module loading. This avoids callbacks to the entity resolver and related interfaces while holding this lock.
IPlugin_configuration::load_plugin_library() function beforehand.
Iray 2021.0.0 beta, build 344800.351 (continued)
Fixed Bugs
Iray 2021.0.0, build 344800.2052
Iray 2021.0.1, build 344800.4174
Fixed Bugs
Iray 2021.0.2, build 344800.7839
- Added support for the "white mode" global diffuse material.
MI importer/exporterFixed Bugs
Daz Studio 4.15.1.91
Iray 2021.0.3, build 344800.8726
Fixed Bugs
Daz Studio 4.15.1.96
Iray 2021.0.4, build 344800.9767
Fixed Bugs
Daz Studio 4.16.1.6
Iray 2021.1.0 beta, build 349500.5279
documentation.
LPE-based approach.
Scenes which set matte_shadow_affects_alpha to false will now trigger a warning and the alpha channel will contain matte shadows. Such scenes are returned to the original result by setting iray_default_alpha_lpe = "[LeLmLms]T*E", provided that they do not already use any specialized alpha LPEs. In that case, adding Lms to the list of captured light types will generally remove matte shadows again.
If invoked as before, the utility functions for alpha LPEs provided by IRendering_configuration now yield expressions which do not have opaque matte shadows. Matte shadows can be made opaque by passing ALPHA_TRANSMIT | ALPHA_MATTE_SHADOW (or similar) to these functions.
geometric normal (OM-37821).
Fixed Bugs
Daz Studio 4.16.1.17
Iray 2021.1.0, build 349500.7063
Fixed Bugs
Daz Studio 4.16.1.34
