Can't find Genesis 8.1?
IceDragonArt
in The Commons
So I've been gone for a wee bit. I was told it should show up in DIM or my content library under 8.1 starter essentials? It does not, and I can'f find it in the shop either.
Who told you such nonsense? Every time the question came up here the emphasis ALWAYS was on that it's an updated Genesis 8 Starter Essentials.
You have to update the Genesis 8 Starter Essentials. I think the other thing to update is also the "DefaultResourcesforDAZStudio415", because it has that "PBR" skin shader in it that a lot of G8.1 figures are using. (If you do this manually, it should be under DAZ Studio 4, in your product library.)
I almost forgot. If you haven't updated to 4.15, G8.1 isn't going to work well out of the box.
Great thanks! I will see what I can do.
Hmm not even sure its worth it then. I have a slightly older machine and honestly, enough content without 8.1 to last a lifetime even if I rendered something new every day. Thanks for the info!
