!! Released !! - mcjGearz : 54 morphing Gear / cogs / toothed things props
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
*** Released ! *** *** Released ! *** *** Released ! *** *** Released ! *** *** Released ! ***
https://sites.google.com/site/mcasualsdazscripts5/mcjgearz
gear teeth profiles are very customizable
you'll even be able to make daisies, or stars or hexagonal, octogonal nuts/bolt heads
note that they are crowns, in the image below, one is mounted on a mcjFlyWheel and another one is mounted on a mcjPlateOnePipe
fig3 - redesigning the teeth for edge sharpening morphs
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    this is not a donut
    this is a gear
    32 teeth
    16 rings of 16 vertices per tooth
    but there will probably be more polygonally economical versions of the supermorphable gears
    1920 x 1080 - 304K
    see, it will even be able to be a crown gear ( teeth above the torus ) or a ring gears ( teeth inside the torus )
    this is just a demonstration, in fact this morph was created using mcjElevate and a displacement map
    628 x 416 - 79K
    1920 x 1080 - 361K
    well today is Sunday so, chances are the super gears will be ready in the next 8 hours time slot :)
    this date also coincides with Hivewire's Dawn SR2 arrival
    ( which by the way, like any vertex based figures could be made to work moderately well in old versions of Poser and Daz, given a little effort )
    Fig 2 - Same donut with sharpen morphs
    Fig3 - it's basically a higher resolution de-evoluted version of the mcjPlateOneHole
    and instead of 4 corners, we want 32 teeth
    Fig 4 - Costom teeth shapes ( 16-steps curves )
    fig 5 getting there ...
    960 x 540 - 116K
    1920 x 1080 - 356K
    1136 x 768 - 204K
    1136 x 768 - 215K
    1000 x 1000 - 912K
  • MilosGulanMilosGulan Posts: 1,987
    Very interesting. I am curious about Dawn figure too :) Thanks for info.
    sinewave teeth
    note that the "sharpen" morphs are not there yet
    Figure 2 : Tada ! the sharp-Edge morphs
    1920 x 1080 - 178K
    1072 x 640 - 185K
    1072 x 640 - 549K
    1920 x 1080 - 812K
    1920 x 1080 - 867K
    not sure yet how the presets will be included/applied
    that's the preset for the most common type of gear
    the "stretch" visual effects are a bit annoying ... but come to think of it, maybe ..... turning the material's "smoothing off" ... yeah it works
    but it's a trick ... guess i'll add a few vertex rings
    figure 3 there you go, i went for this solution. each one of the 16 rings of facets has its own material
    so but turning "smoothing" off on the top, bottom and hole-walls, we get rid of "stretch marks"
    1920 x 1080 - 1M
    1920 x 1080 - 380K
    1920 x 1080 - 271K
    1920 x 1080 - 388K
    1920 x 1080 - 426K
    neato !
    ring gears and crown gears !
    1920 x 1080 - 1M
    1920 x 1080 - 928K
    1920 x 1080 - 881K
    1920 x 1080 - 840K
    the shape of all 32 teeth will be fine-tunable using 16 "radius" morphs and 16 "rotate" morphs
    figure 5 - problem with sharpness
    possibly due to the order in which the radius and sharp morphs are applied
    1054 x 653 - 292K
    1920 x 1080 - 305K
    1920 x 1080 - 229K
    636 x 628 - 137K
    1174 x 666 - 249K
    here you can see my problem to solve
    the small gear edge sharpness morph is all messed up by the teeeth-morph
    but the large 32 teeth gear doesnt have that problem
    maybe .... the Poser scale is causing a loss of precision?
    hmm, i know, i'll compare teeth number 0's deltas in both props
    ( pretty sure i did normalize my "push" vectors" so they should not be influenced by the initial vertex position )
    Found it !!! i think .... the teeth morph maker was working on the assumption that there were 32 teeth, not 8
    yep that was it , my script was probably piling up morph deltas 4 times
    there will probably be 5 x 2 x 3 ... that's 30 props
    8, 12, 16, 24, 32 teeth
    though the 32-teeth prop will be able to morph into a 64 and 128 teeth gear
    4, 8 or 16 "slices" per tooth
    8 or 16 segment per "slice"
    so a minimal resolution 32-teeth gear will be 8 x 4 x 32 = 1024 faces
    a full-resolution 32-teeth gear will be 16 x 16 x 32 = 8192 faces
    1280 x 720 - 90K
    1920 x 1080 - 911K
    1280 x 720 - 355K
    well i'm wrote most of the script to generate the 30 props and their hundreds of morph channels
    Figure 1 and 2 the 256-faced morphing donut - which will "carry" a slider to turn it into an 8-teeth gears
    but since those props are very versatile, i dialed-in an octagon nut !
    FIG 3
    fig 4 the 6 resolutions for the 8-sided or 8-toothed props
    763 x 1080 - 397K
    1038 x 770 - 278K
    1440 x 1080 - 575K
    1920 x 1080 - 831K
    since i automatized the production of the morphing props,
    and since it can be used for other things than gears
    i will include 3, 4, 5, 6 teeth props ( each in 5 resolutions )
    for a grand total of 54 props
    in the very distant future i may make the same without the center hole
    Fig 2 note that if you google a bit you can find online gear design apps
    http://hessmer.org/gears/InvoluteSpurGearBuilder.html
    and with some photoshopping you could create transparency and/or displacement maps, and build fake 1-polygon gears
    fig 3 maximum teeth will probably be 128, using the 32-teeth torus
    fig 4 fake gears using an opacity and displacement map ( negative image of figure 3 )
    fig 5 - half way done adjusting the default teeth for the 3, 4, 5, 6, 8, 12, 16, 24, 32 teeth gears
    1920 x 1080 - 648K
    960 x 720 - 325K
    1400 x 1000 - 196K
    1370 x 879 - 143K
    1440 x 1080 - 454K
  • Miss BMiss B Posts: 3,071
    WOW, these look wonderful. I'm already thinking how I could use them. :coolsmile:
    Looking good :) will try to use them too.
    each prop will have a master slider to turn it into a
    - spur gear
    - top face gear ( crown gear )
    - bottom face gear
    - Internal ring gear
    when you load the prop, it will be a spur gear, with moderately sharp edges, and an appropriate hole size
    i mean if the Timbits were larger than the donuts and it wouldn't make sense would it?
    ( the base prop is a smooth torus with no teeth )
    figure 2, the result of applying the spur-gear's teeth profile to the crown gears and the ring gears .... i'll probably improve on this
    1456 x 768 - 603K
    968 x 550 - 81K
    1920 x 1080 - 559K
    1166 x 649 - 348K
  • ThatGuyThatGuy Posts: 797
    these look really cool. Can't wait for you to make them available!
    high hopes for a Thursday release
    i just have to see if the poser-prop exporter part of my script is ready to export the 54 , now, fully functional props
    figure 2, had to change the teeth growing master controls, so the teeth grow outward, though i may retain the teeth carving control
    1920 x 1080 - 936K
    1920 x 1080 - 595K
    1920 x 1080 - 646K
  • stronghandsstronghands Posts: 104
    Wow. Awesome work on these. Excellent tooth profile too.
    today or tomorrow i'll post the .obj grouping tool
    it was hardcoded in a way only i could use it,
    but now it should work for anyone
    provided you have windows/msdos
    and you can write and run a batch file like this:
    though i will publish the cpp source code so someone else could compile it and run it in Mac or Linux
    the file named GROUP_mcjSLWomanJumper.bat
    located in the same folder as mcjObjGroupByProximity .exe
    SET MCJA="C:\\\\Program Files (x86)\\\\DAZ\\\\Studio\\\\content\\\\Runtime\\\\libraries\\\\Character\\\\SL Avatar\\\\SL_Female.obj"
    SET MCJB="C:\\\\Program Files (x86)\\\\DAZ\\\\Studio\\\\content\\\\Runtime\\\\libraries\\\\Character\\\\SL Avatar\\\\old_mcjSLWomanJumper.obj"
    SET MCJC="C:\\\\Program Files (x86)\\\\DAZ\\\\Studio\\\\content\\\\Runtime\\\\libraries\\\\Character\\\\SL Avatar\\\\mcjSLWomanJumper.obj"
    mcjObjGroupByProximity %MCJA% %MCJB% %MCJC%
    pause
    the free SecondLife avatar is a poser compatible figure, it has the proper groups
    SL_Female.obj is the "reference" figure, or donor
    old_mcjSLWomanJumper.obj is the non-grouped clothing item i modeled
    mcjSLWomanJumper.obj is the resulting clothing item with all its 6000 faces grouped by the proximity to the facets in the reference figure
    1600 x 900 - 437K
    800 x 450 - 75K
    This will be a most useful tool for those of us still working with older figures.
    ready http://www.daz3d.com/forums/discussion/48986/
    been using that for quite a while
    to make clothes for Aiko3's default body it's quite fast
    gears news bulletin
    the 54 gears now exist as poser-prop+obj files !
    up to now they were "living" in a daz scene file
    Sunday normally, all i have left to do is add the default spur-gear state
    package the whole thing
    make the web page for the release, and it's done !
    then i'll resume work on the machine-animator script
    here you see the 3, 4, 5, toothed props
    unzipped, the prop files are about 34MB, zipped they are 4MB
    the geometry (obj) files are 10MB unzipped and 1.6MB zipped
    though nowadays it doesnt matter since our Vic20's have big cassettes
    in other news, today is the day ( knock on wood that the props work as-is in my Poser 7 and 9 )
    973 x 754 - 374K
    1920 x 1080 - 512K
    1920 x 1080 - 396K
    release is very close, it's today ! yay
    theres 54 props
    tooth count : 3, 4, 5, 6, 8, 12, 16, 24 or 32
    slices per tooth : 4, 8 or 16
    sides per slice : 8 or 16
    16 slices per tooth gives you detailed tooth shape-ability
    16 sides per slice gives you better edge sharpening
    718 x 656 - 156K
    1920 x 1080 - 860K
    1920 x 1080 - 444K
    Quick Tip - Turn Off the "smooth" option for surfaces that need to appear very flat ( gear sides and Hole )
    1600 x 900 - 716K
    867 x 612 - 172K
    Oh, this is going to be fun to play with. :coolsmile:
    tho just now i realized the one-toothed "gear" is needed
    using it you could make bracelets and other irregular rings
    they'll have a different name i guess, not "gear"
    500 x 500 - 56K
