Iray server: weaker machines providing lower quality results
HI!
I've started playing with Iray server recently. Yesterday I sent several jobs to a strong RTX 2070 machine and to an older GTX960 laptop. When I checked the results I found that the GTX results were much grainier than the ones in the newer machine.
Assuming I'm in no rush and can give the GTX960 all the time it needs, are there any configurations which will help me acheive better quality on the images it renders?
I've not used Irayn server, but does it have the same stop conditions in DS? If so two hours is the default and, depending on the scene, that might not be as long as neede.
Thanks, I'll check it out.
