Simple Text from Hexagon Rendering
I am a new user to this function.  I used Hexagon to make two words ("Test text") and exported them as an .obj.  The .obj was then imported into DAZ using the Hexagon preset.  Everything looks okay in simple wireframe view, but when rendered the text does not look correct, with some triangles joining the high points of the "t" and other letters.  Could anyone point me to what I'm doing wrong, or to a step-by-step on generating text in Hexagon for rendering in DAZ?
Thanls
  • margravemargrave Posts: 1,822
    edited October 2021
    You need to remesh the front faces in Hexagon so they're triangles or quads, instead of n-gons (faces with more than four vertices).
    Post edited by margrave on
  • AscaniaAscania Posts: 1,855
    And if you go back a page or two on the Hexagon subforum you will find all the relevant explanations from the last time someone asked about it.
