Please FIX Umbra Outfit (micro pressure morphs)
Hi all,
Umbra outfit by Herschel Hoffmeyer (https://www.daz3d.com/umbra-outfit-for-genesis-8-and-81-females) needs fixing with its pressure morphs. None of the pressure morphs work with G8F despite the outfit being advertised to be compatible with the G8F figure. In addition, the Umbra Strap Arm Right Micro Pressure PRESET does not work properly with the G8.1F. Hand poses only work for G8.1F.
Let me be more specific.
G8F figure:
None of the micro pressure morphs work, they don't even show up in the parameters tab or shaping tab. Hand poses do not work either.
G8.1F figure:
All ON and OFF micro pressure morphs work with the exception of the ON Umbra Strap Arm RIGHT Micro Pressure. The ON PRESET applies the micro pressure on the LEFT side, and the morph slider (for the right arm) doesn't show up in the parameters tab. However it does show up in the shaping tab and it does work when you move the slider. Pressing the OFF PRESET for the right arm will correctly remove the morph. Hand poses work but they move the figure back to the origin.
Cheers.
My apologies forgot to mention...
The hand poses is for the add-on https://www.daz3d.com/cyber-samurai-expansion-for-umbra-outfit
Cheers.
He's apparently updated it. https://www.daz3d.com/forums/discussion/521151/umbra-outfit-for-genesis-8-8-1-females-commercial#latest
Oh cool, thanks for the link...
Looks like he's still working on the fix as I don't see any updated version on my DIM.
Cheers.
Yes there has been 3 updates released for this product already. Some users are seeing this in their DIM while others are not. I would contact Daz and explain to them that they have published updates for this product but they're not showing up in your DIM.
Hi Herschel,
One quick question before I contact DAZ. When did you submit your latest update for this product?
I was hoping to just download manually from my product page today (24 OCt) but after comparing files, it is the same as the one I currently have.
Cheers.
Thanks Herschel.
I think is best to close this thread and focus on your product official one. I did a trial and error and updated my results there.
Cheers.
