Genesis joints are fallout out of place.
deleted userdeleted user Posts: 1,204
When I transit my genesis up or down the joints fall out of place and distort the figure.
Can anyone help me please?
  • fixmypcmikefixmypcmike Posts: 19,702
    What morphs do you have applied?
  • deleted userdeleted user Posts: 1,204
    None this is a zeroed figure.
    The body is stretched and the head is tiny, that is not the default zero shape of Genesis. I suspect you have a bad morph or morph set installed.
    Does your Genesis load with breasts?
    edited November 2014
    Yes it does. I solved the issue. It's not a bad morph, a mishap during edit mode on parameters.
    Somehow I accidentally did an ERC Freeze on the transit for a morph while in edit mode. I had to delete that morph to reverse this.
    I found it by going into parameter settings and looking in sub components
    Post edited by deleted user on
    Oh, wanna know the funny part? The answer came to me in a dream. I mean that quite literally. :D
    I certainly believe it -- if you think about a problem for a while before going to sleep, your mind keeps working on it.
    So basically I was right.
