Genesis joints are fallout out of place.
deleted user
When I transit my genesis up or down the joints fall out of place and distort the figure.
Can anyone help me please?
deleted user
What morphs do you have applied?
None this is a zeroed figure.
The body is stretched and the head is tiny, that is not the default zero shape of Genesis. I suspect you have a bad morph or morph set installed.
Does your Genesis load with breasts?
Yes it does. I solved the issue. It's not a bad morph, a mishap during edit mode on parameters.
Somehow I accidentally did an ERC Freeze on the transit for a morph while in edit mode. I had to delete that morph to reverse this.
I found it by going into parameter settings and looking in sub components
Oh, wanna know the funny part? The answer came to me in a dream. I mean that quite literally. :D
I certainly believe it -- if you think about a problem for a while before going to sleep, your mind keeps working on it.
So basically I was right.
