mcjPlateOneRod - DS/Poser mechanical hyper morphing prop
mCasualmCasual Posts: 4,607
edited December 2014 in Freebies
download : https://sites.google.com/site/mcasualsdazscripts4/mcjplateonerod
History
December 2nd 2014 0:07 am - the "master controls" were not connected to the morphs
November 7th 2014 8:33 pm - Added the tons of very important morph-groupings
November 7th 2014 7:12 pm - Released
basically it's the mcjPlateOnePipe with the interior of the pipe removed
the hole size will be 0 by default but will have an adjustable radius and position
that hole will be adjustable between circular or rectangular ..... like all the other rings and edges
fig 3 if you see what i mean, this UV mapping should enable many interesting effects
there's 9 materials, so if you un-sharpen an edge, you only need to readjust 1 UV map
all the UV maps are 1x32 or 8x32 rectangular grids
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited November 2014
    Warning: if you downloaded the prop in the first hour
    then your pop is missing the very very important morph-groupings
    1280 x 540 - 187K
    1280 x 540 - 186K
    1280 x 540 - 211K
    870 x 870 - 147K
    Update - Update - Update - Update - Update - Update - Update -
  • ElowanElowan Posts: 388
    Keep 'em coming dude!:coolsmile:
    Update Update
    well it's not really a crucial update but be aware that mcjplateonerod's
    initial distribution zip file contained a Runtime folder which contained
    the mcjPlateOneHole Runtime folder and content
    ( I did this accidentally while copying the Textures folder and its fake-chrome reflection textures )
    The new zip file contains just the mcjPlateOneRod folders and files
    you may also want to delete ( careful there ! yeah i know you know that )
    or move any runtime folder which is found in your runtime folder
    important update
    and those master controls make life much easier
    1920 x 1080 - 989K
    960 x 540 - 301K
