DCG obj sequence (solved) and a way to import dforce animations and DAZ content
WendyLuvsCatzWendyLuvsCatz Posts: 40,561
edited October 2021 in Carrara Discussion
has anyone used the DCG obj sequence importer?
is there some trick to getting it to import more than one object?
I used @TheMysteryIsThePoint  Sagan to to export 600 dressed G8M dforced objects from DAZ studio but it only imports the first one
is it the naming?
they are named 00000.obj - 00600.obj
actually because they possibly are all the same vertex order (not sure as file sizes do vary) it would be cool if someone made a timeline sequenced morph importer enlightened
SOLVED
in Wrench tab Animate slider
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,561
    I am thinking outside the box and considering batch converting them all to stl and loading them in FLUIDOS cheeky
    edited October 2021
    Meh surfaces or UV mapping might be messed up, possibly UDIM
    no way to check as no vertex room for it
    tried both on my Carrara settings obj export
    Used some Octane shaders could proceedurals otherwise, some work but a lot don't including the lips, original on the right
    Octane render, Octane does pause and let each object load before render
    DCG importer must do it as the Sagan objs have the correct UVs
    is a shame as the Dforce Sim, HD figure etc import perfectly
    is useable but textures a bit of an issue due to UV mapping, are mapped just not correctly, likely u is ticked!!!!!!!!
    1920 x 1080 - 1M
    1920 x 1040 - 222K
    1920 x 1080 - 1M
    edited October 2021
    short animation, redoing better camera shot and a scene
    I also replaced his skin with a colour for the next one as the UV mapping is all wrong
    I might need to fix this with a collapsed UV in D|S on the clothes too if UDIM mapped
    meh the teeth too
    1920 x 1080 - 5M
    edited October 2021
    and I solved it, I did do a collapsed UV but it was in fact an export option in Sagan
    not the Cage subdiv but the other subdivision option
    1920 x 1080 - 274K
  • DartanbeckDartanbeck Posts: 21,988
    Wow. What a game changer!!!
    So let me see if I get this:
    1. Possibly collapse UDIM to single plane UV
    2. Sagan Export using the other SubD option than "Cage"
    3. Import to Carrara using DCG's OBJ Sequence
    Then what, do we need to scrub each frame and move the animation slider along in the Assemble Room modeling?
    In your examples, what all is imported in this way - just the clothing, the whole character...?
    edited October 2021
    I will try and whip up a tutorial when I finish rendering my animation kiss will try and answer some of that now
    Sagan is under edit tab BTW not File
    also for some bizzare reason Sagan (and Unreal exporter and a few other plugins) only work in D|S4.11 on my Win10, all do on 4.15 beta on my Win7, I have a lot of weird issues on Win10 with DAZ blush
    UDIM is a red herring, it was the obj sequence type, there are 4 options
    you can delete the huge abc file and python files as we only need the folder of obj files
    1293 x 630 - 64K
    edited October 2021
    in wrench/spanner tab you get this instead of vertex modelling room
    you set the slider for the frames you want the objs to load so 100% at begining and 0% at end for a reverse animation
    if you want a longer slower animation or one that mirrors you set the frames accordingly and the objs will linger longer or skip
    1203 x 813 - 117K
    edited October 2021
    oh and yes whole dressed animated character
    is a series of obj exports,
    can be a whole scene if so inclined but that's a bit pointless cheeky
    Agreed!
    Okay Cool! Thanks a miilion! smiley heart
    Video rendered,
    the DM set was loaded from my browser,
    Octane render but native obviously works too
    too tired to do a tute now, will think about later
    Awesome. So it really works! So Cool!
    it might prove useful for people like @UnifiedBrain who don't have Misty's presets and as it loads the geometry as exported is fully subdivided HD and Dforce sims baked each obj that loads, this one the objs loaded reasonably fast (a couple of seconds) for IIRC subdivision 3 on the character.
    The shader hierarchy applies to them all once set up for the first one.
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Wendy,
    Thanks for thinking of me - but your discovery is mostly over my head. :)
    I will try again to understand if you get a tutorial done.  But those are a lot of work, so I don't blame you if it doesn't happen.
    And I hope that it goes without saying, if this process requires animation skills, then I probably won't dig in.  Haven't learned animation yet, and right now is not the best time.  Too many other irons in the fire.
    But if it helps bring in G3 or G8 with full morphs, that would be cool.
    UnifiedBrain said:
    Wendy,
    no, it is just objs, lots of them loaded in sequence
    but you can do a series of poses too and render them out
    that would be a lot less objects so easier
  • HeadwaxHeadwax Posts: 10,459
    WendyLuvsCatz said:
    UnifiedBrain said:
    Wendy,
    thanks for going where no person has gone before - again!
    Headwax said:
    WendyLuvsCatz said:
    UnifiedBrain said:
    Wendy,
    Right?!!! Wendy... You ROCK!!! heart
