Updated - mcjPlateOneHole - versatile morphing DS/Poser mechanical prop
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
the mcjPlateOneHole
right there -----> https://sites.google.com/site/mcasualsdazscripts4/mcjplateonehole
round, or square, or oval plate with a round or square or oval hole
Note that once the prop was morphed to satisfaction,
i did use mcjBoxUV http://www.daz3d.com/forums/discussion/36930/
to re-lay the UV map and obtain such an un-stretched result
i applied the free bump map .... mcjNeoprene1k http://www.daz3d.com/forums/discussion/46444/
and tiled it 40x20
( actually i had to use bizarre bump map values to invert the bumps : min=0.02 max=0 )
fig 3 is the (DS3 ) subD
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    Fig 1 - the 4 main Corners / AwayX and Corners/AwayZ morph-groups
    Fig 2 - adding the Corners, Radius morph-groups
    Fig 3 - adding the Corners / Sharp morph-groups
    Fig 4 oops actually there were 5 slider-tweak if you add the PipeSharp and PlateSharp morph-groupings
    Fig 5 The "Levels" morph groupings, only 2 levels so ...
    1386 x 772 - 392K
    958 x 866 - 304K
    960 x 960 - 418K
    960 x 960 - 344K
    1544 x 918 - 564K
    And finally the "Sides" morph-groupings
    4 sides : left, back, right, front
    2 morphs : AwayX, AwayZ
    Top and Bot
    Plate and Pipe(Hole)
    so, 32 channels
    still have to do:
    - reassign a materials a tad better
    - re-UV?
    - rename materials
    - rename morphs that use "pipe" with "hole"
    - create google site
    - package
    - publish
    ...under an hour left :)
    Figure 2 ... yep it can also be a thick or thin, sharp or blunt-edged pipe !
    Figure 3 ... and even a squary pipe with round or sharp corners
    Figure 5 - the "Expanders" morph-groupings actually marshal up to 24 morphs at once
    ( 8 corners , the Radius, AwayX and AwayZ morphs )
    the result is what you'd expect a "radius" morph to do
    1318 x 670 - 212K
    960 x 540 - 189K
    960 x 540 - 165K
    960 x 540 - 161K
    960 x 540 - 159K
    so that's the basic mcjPlaneOneHole
    32 sides, 8-steps-edges give it a smooth appearance even when seen up close
    1152 facets ( ( 4 x 8 + 4 ) x 32 )
    since i use automated tools to build morphs and morph-groupings
    i should be able to include a few other versions !
    say
    32x4, 32x2, 16x8, 16x4, 16x2,
    so if your scene uses 100 mcjPlaneOnePipe as simple small washers
    you'll be able to keep the polycount at 19200 instead of 115200
    the groupings
    Corners
    pipeAwayX
    pipeAwayZ
    pipeBotAwayX
    pipeBotAwayZ
    pipeBotRadius
    pipeBotSharp
    pipeBotUp
    pipeRadius
    pipeSharp
    pipeTopAwayX
    pipeTopAwayZ
    pipeTopRadius
    pipeTopSharp
    pipeTopUp
    pipeUp
    plateAwayX
    plateAwayZ
    plateBotAwayX
    plateBotAwayZ
    plateBotRadius
    plateBotSharp
    plateBotUp
    plateRadius
    plateSharp
    plateTopAwayX
    plateTopAwayZ
    plateTopRadius
    plateTopSharp
    plateTopUp
    plateUp
    Expanders
    pipe
    pipeBot
    pipeTop
    plate
    plateBot
    plateTop
    Levels
    LevelsBotAwayX
    LevelsBotAwayZ
    LevelsBotRadius
    LevelsBotSharp
    LevelsBotUp
    LevelsTopAwayX
    LevelsTopAwayZ
    LevelsTopRadius
    LevelsTopSharp
    LevelsTopUp
    Sides
    pipeBotFrontAwayZ
    pipeBotLeftAwayX
    pipeBotRearAwayZ
    pipeBotRightAwayX
    pipeFrontAwayZ
    pipeLeftAwayX
    pipeRearAwayZ
    pipeRightAwayX
    pipeTopFrontAwayZ
    pipeTopLeftAwayX
    pipeTopRearAwayZ
    pipeTopRightAwayX
    plateBotFrontAwayZ
    plateBotLeftAwayX
    plateBotRearAwayZ
    plateBotRightAwayX
    plateFrontAwayZ
    plateLeftAwayX
    plateRearAwayZ
    plateRightAwayX
    plateTopFrontAwayZ
    plateTopLeftAwayX
    plateTopRearAwayZ
    plateTopRightAwayX
    455 x 455 - 66K
    hmm i guess all that's left to do is make sure the materials are ok
    and change the mentions of "pipe" for "hole"
    see? earrings
    the superb hair comes from http://swam3d.com/audry-hair/
    1600 x 900 - 652K
    1920 x 1080 - 923K
    640 x 360 - 1015K
    960 x 540 - 78K
    tis ready
    ( though now i remember i vaguely promised i'd post alternate polygon-count versions .... later )
    455 x 455 - 92K
    Warning - Warning - Warning - Warning -
    impending update
    the "Sharp" morphs are apparently not functioning correctly
    though it has interesting side effects
    ( the tub shape is the upcoming mcjGear prop a toothless gear in this case )
    1070 x 612 - 463K
    update - update - update - update - update - update - update - update - update
    The "Sharp" morphs have been corrected
    ( the maths for sharpening an external edge and sharpening a hole edge are different and i somehow inverted them )
