Need HELP please! Daz does not render with 1050ti
Hi yall, Well I honestly don't know what to do anymore so I come here for your help, Since yesterday daz is not rendering anything at all, After having tried to clean up assets by uninstalling some things from Daz Central, That is the only thing I could say that I did outside than usual, then just install some new assests in the same old way. All these days I had been working normally without any changes in my editing and rendering routine.
I already tried everything, From updating the drivers to the new version Game ready 496.13, Then change to the latest version of studio, Also thinking that the problem could be related to the assets I tried to do everything with the options offered by the Content DB Maintenance, Search drives for files, and so. Of course I also tried everything in the render settings changing from GPU to CPU and both, changing multiple things in the advanced tab, And NOTHING changes.
I don't know what else to do, I leave an example in which I try to render a scene that I render it TWO DAYS AGO perfectly, but now it doesn't even let me preview in Nvidia Iray mode. I leave the screenshots of the errors, The scene info, and the txt log in which I do not understand much but many warning messages call my attention. What I did in the example is to restart the pc, just start it open Daz, load the scene, and once everything is ready click to render, and that happened. I also noticed that when I open daz the memory starts up with almost 1500mb, and when trying to render, for an moment the CPU usage increases and the GPU does not move.
Please can someone guide me to a possible solution
    I am surpriced that you were able to render that scene two days ago on a 4GB GPU...
    I think what made the scene go overboard was the new assets you installed, if you haven't changed anything else.
    If you restart your computer, open DS and load just one of the primitives, does it render in Iray?
  • Il_AlemanIl_Aleman Posts: 2
    edited October 2021
    Yep XD, That's right But hey, you do what you can with what you have, So far I was able to do almost 900 renders like this in a project that I started a year and a half ago (Not so much for the renderings themselves, but for the little time that I dedicate to it, This is kind of a hobby in my spare time) But yes, I could do it with HQ results, Obviously always suffering from the limitations of my system and doing everything not to load it too much, but now it won't even let me render. As for the pre-render of nvidia iray, I just checked it let me do it, and according to the resource monitor it is doing it with the GPU without fallback, but when I try it to finally render it gives me the same errors.
    Edit; Yes, when I reboot the system the same thing happens, I also forgot to say that the error is with any scene even if it is a simple object.
    Post edited by Il_Aleman on
    I wouldn't try to use Iray Preview with your system. The error message says "Unable to render. Renderer is already in use", use 'Texture Shaded' instead.
    With such limited resources, the Iray preview may not release the renderer, therefore preventing the rendering.
    An other thing to consider is, do you use a default opening scene with things loading automatically. Try deleting everything in the scene tab and using environment setting "Scene Only", are you able to render a primitive ball in Iray?
    edited October 2021
     Yes look i just tried with a simple primitive sphere and the same error. And yes, In fact, I always use the batch render script and let 5 or 10 scenes per night to render (Tuesday was the last time I did it and everything turned out perfect as always)
    I leave below the log txt, and the render data (which is the one I use almost always, obviously changing the quality between UHD or QHD, the max time and the render quality depending on what I need to render) which I just tried to render the sphere and it gave me the same error, This time using only the GPU with fall back on, And the Iray preview mode worked perfect.
    Oh by the way, The error is thrown at me instantly after pressing the render button.
    Linking Shader:
    Shader Program successfully linked.
    2021-10-16 15:33:26.584 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
    2021-10-16 15:33:26.585 Metadata update succeeded.
    2021-10-16 15:34:21.159 WARNING: QColor::setRgb: RGB parameters out of range
    2021-10-16 15:34:21.165 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2021-10-16 15:34:21.179 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2021-10-16 15:34:21.179 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2021-10-16 15:34:21.179 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2021-10-16 15:34:21.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 0.99 (Full instancing compression ratio 0.97)
    2021-10-16 15:34:21.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2021-10-16 15:34:21.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 530 triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 530 triangles, 0 fiber instances yielding 0 segments) took 0.000s
    2021-10-16 15:34:21.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2021-10-16 15:34:21.181 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 0 textures, 0 lambdas (0 unique)
    2021-10-16 15:34:21.181 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.000s
    2021-10-16 15:34:21.181 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2021-10-16 15:34:21.190 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2021-10-16 15:34:21.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2021-10-16 15:34:21.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2021-10-16 15:34:21.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2021-10-16 15:34:21.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2021-10-16 15:34:21.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2021-10-16 15:34:21.197 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2021-10-16 15:34:21.197 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2021-10-16 15:34:21.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2021-10-16 15:34:21.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2021-10-16 15:34:21.201 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using OptiX Prime version 5.0.1
    2021-10-16 15:34:21.201 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX Prime for CUDA device 0
    2021-10-16 15:34:21.248 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2021-10-16 15:34:21.248 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti)
    2021-10-16 15:34:21.248 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2021-10-16 15:34:21.248 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): Processing scene...
    2021-10-16 15:34:21.249 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Geometry memory consumption: 16.859 KiB (device 0), 0.000 B (host)
    2021-10-16 15:34:21.260 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Texture memory consumption: 0.000 B for 0 bitmaps (device 0)
    2021-10-16 15:34:21.260 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2021-10-16 15:34:21.260 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2021-10-16 15:34:21.261 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.001s
    2021-10-16 15:34:21.262 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Lights memory consumption: 948.000 B (device 0)
    2021-10-16 15:34:21.267 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Material measurement memory consumption: 0.000 B (GPU)
    2021-10-16 15:34:21.267 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Materials memory consumption: 23.602 KiB (GPU)
    2021-10-16 15:34:21.417 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): Scene processed in 0.169s
    2021-10-16 15:34:21.421 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): Allocated 13.878 MiB for frame buffer
    2021-10-16 15:34:21.442 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): Allocated 1.750 GiB of work space (2048k active samples in 0.021s)
    2021-10-16 15:34:21.442 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2021-10-16 15:34:21.671 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 0.414s.
    2021-10-16 15:34:21.676 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2021-10-16 15:34:21.747 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 0.485s.
    2021-10-16 15:34:21.792 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00003 iterations after 0.529s.
    2021-10-16 15:34:21.843 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00004 iterations after 0.580s.
    2021-10-16 15:34:21.893 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00006 iterations after 0.630s.
    2021-10-16 15:34:22.044 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00009 iterations after 0.781s.
    2021-10-16 15:34:22.065 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00012 iterations after 0.803s.
    2021-10-16 15:34:22.224 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00015 iterations after 0.962s.
    2021-10-16 15:34:22.272 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00018 iterations after 1.009s.
    2021-10-16 15:34:22.350 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00021 iterations after 1.088s.
    2021-10-16 15:34:22.512 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00027 iterations after 1.250s.
    2021-10-16 15:34:22.789 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00034 iterations after 1.526s.
    2021-10-16 15:34:23.005 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00041 iterations after 1.743s.
    2021-10-16 15:34:23.094 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00048 iterations after 1.831s.
    2021-10-16 15:34:23.275 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00055 iterations after 2.013s.
    2021-10-16 15:34:23.610 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00062 iterations after 2.347s.
    2021-10-16 15:34:23.648 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00069 iterations after 2.386s.
    2021-10-16 15:34:23.988 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00076 iterations after 2.725s.
    2021-10-16 15:34:24.041 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00083 iterations after 2.778s.
    2021-10-16 15:34:24.230 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00090 iterations after 2.967s.
    2021-10-16 15:34:24.441 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00097 iterations after 3.179s.
    2021-10-16 15:34:24.607 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00104 iterations after 3.344s.
    2021-10-16 15:34:24.932 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00111 iterations after 3.670s.
    2021-10-16 15:34:24.982 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00118 iterations after 3.720s.
    2021-10-16 15:34:25.181 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00125 iterations after 3.919s.
    2021-10-16 15:34:25.361 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00132 iterations after 4.098s.
    2021-10-16 15:34:25.553 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00139 iterations after 4.290s.
    2021-10-16 15:34:25.745 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00146 iterations after 4.482s.
    2021-10-16 15:34:25.974 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00153 iterations after 4.711s.
    2021-10-16 15:34:26.136 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00160 iterations after 4.873s.
    2021-10-16 15:34:26.331 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00167 iterations after 5.069s.
    2021-10-16 15:34:26.543 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00174 iterations after 5.281s.
    2021-10-16 15:34:26.723 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00181 iterations after 5.461s.
    2021-10-16 15:34:26.893 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00188 iterations after 5.631s.
    2021-10-16 15:34:27.087 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00195 iterations after 5.824s.
    2021-10-16 15:34:27.299 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00202 iterations after 6.036s.
    2021-10-16 15:34:27.490 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00209 iterations after 6.227s.
    2021-10-16 15:34:27.664 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00216 iterations after 6.402s.
    2021-10-16 15:34:27.840 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00223 iterations after 6.578s.
    2021-10-16 15:34:28.015 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00230 iterations after 6.752s.
    2021-10-16 15:34:28.354 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00237 iterations after 7.091s.
    2021-10-16 15:34:28.387 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00244 iterations after 7.125s.
    2021-10-16 15:34:28.647 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00251 iterations after 7.385s.
    2021-10-16 15:34:28.771 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00258 iterations after 7.509s.
    2021-10-16 15:34:28.960 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00265 iterations after 7.698s.
    2021-10-16 15:34:29.153 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00272 iterations after 7.891s.
    2021-10-16 15:34:29.398 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00279 iterations after 8.135s.
    2021-10-16 15:34:29.548 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00286 iterations after 8.286s.
    2021-10-16 15:34:29.875 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00293 iterations after 8.612s.
    2021-10-16 15:34:29.926 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00300 iterations after 8.663s.
    2021-10-16 15:34:30.254 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00307 iterations after 8.991s.
    2021-10-16 15:34:30.307 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00314 iterations after 9.044s.
    2021-10-16 15:34:30.493 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00321 iterations after 9.230s.
    2021-10-16 15:34:30.665 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00328 iterations after 9.402s.
    2021-10-16 15:34:30.871 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00335 iterations after 9.608s.
    2021-10-16 15:34:31.062 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00342 iterations after 9.799s.
    2021-10-16 15:34:31.301 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00349 iterations after 10.038s.
    2021-10-16 15:34:31.760 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00356 iterations after 10.497s.
    2021-10-16 15:34:31.815 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00370 iterations after 10.552s.
    2021-10-16 15:34:32.892 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00398 iterations after 11.629s.
    2021-10-16 15:34:33.647 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00441 iterations after 12.384s.
    2021-10-16 15:34:35.264 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00488 iterations after 14.002s.
    2021-10-16 15:34:36.241 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00540 iterations after 14.978s.
    2021-10-16 15:34:37.751 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00597 iterations after 16.489s.
    2021-10-16 15:34:39.322 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00660 iterations after 18.060s.
    2021-10-16 15:34:41.118 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00729 iterations after 19.856s.
    2021-10-16 15:34:43.094 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00805 iterations after 21.831s.
    2021-10-16 15:34:45.264 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00889 iterations after 24.002s.
    2021-10-16 15:34:47.642 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00982 iterations after 26.379s.
    2021-10-16 15:34:50.270 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01083 iterations after 29.008s.
    2021-10-16 15:34:53.131 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01195 iterations after 31.868s.
    2021-10-16 15:34:56.281 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01319 iterations after 35.018s.
    2021-10-16 15:34:59.866 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01455 iterations after 38.604s.
    2021-10-16 15:35:02.168 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2021-10-16 15:35:02.168 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1050 Ti): 1455 iterations, 0.449s init, 40.482s render
    2021-10-16 15:35:19.686 Loaded image: DTHDR-RuinsB-500.hdr
    2021-10-16 15:36:36.070 Total Rendering Time: 28.70 seconds
    303 x 157 - 9K
    397 x 366 - 30K
    527 x 800 - 30K
