Render to RIB for mulitple frames
I know you can export Render to RIB and use stand alone 3delight to render the scenes as explained in the below doc.
http://deslea.deviantart.com/art/Tutorial-Distributed-Rendering-with-DAZ-3Delight-440675122
This does not work for mulitple frames. it always export one frame as discussed in the below discussion.
http://www.3delight.com/en/modules/PunBB/viewtopic.php?id=3947
I was trying the same thing but it is a bug in the DAZ3D.
I would like to write a script to export mulitple frames to RIB. Can you please forward me to the API documentation, How to write a script to do that.
I need to know.
1) How to interate through all the frames with all the presets, shaders, lights, camera and material.
2) API to access "Render to RIB" Objects. and API for the export.
Thanks,
-A
I'm not sure I understand your exact need but maybe this could help you :
http://www.daz3d.com/batch-render-for-daz-studio-4-and-rib
