How to create 3D Neon letter signs
How to create letters and put in on a wall and make it glow neon like in this
http://www.daz3d.com/real-lights-for-daz-studio-iray
Post edited by videoninja719 on
Take a modelled lights, or a plane with the letters in white on a black ground applied to Cutout Transparency, with the Iray Uber Base shader applied and adjust the Emissive settings in the shader. Or use the linked product.
thanks. But how do i create these 3D letter or planes? do i need to create it in a 3d modeler program like Blender or Hexagon or i can create it in daz? i need help
A plane can be made with Create>New primitive, and the image (white text on black) made in an iamge editor or even by taking a s creen-shot of a text editor. 3D text can be made in a modeller or using soemthing like Font to Mesh Express in the store.
thanks. sorry maybe i didnt mention the correct word properly. I am trying to create 3D neon letter signs like in the link.
Blender has a typography tool that will let you create real 3D letters. This tutorial gives a decent overview. Once you've created the text, you can convert to mesh and export it as an obj. Since you're going for a neon effect, you probably don't even need to UV map.
Google for "neon" fonts ... takes awhile to make fonts work right but some can be then modeled in Hexagon although washing fonts through Elefont to Bryce to export out .obj for import into Hexagon usually works better.
There are the Perspex cutouts, where cut-outs can be made in 2D or 3D letters of LED Neon. It can also be made into logos, signs, letters, and symbols and these make elegant statements regarding the business, the product being sold, or the service being advertised. These letters are either flat or can be fabricated. These cutouts can be then placed on signage boards. The material allows for being easy to work with as well as you can create interesting designs using this material. This material also has high gloss and it has a long life of even up to 10 years when outdoors.
