Cut it out
13»
  • I've built it for Windows and, so far, it doesn't work sad
    I have to explore deeper why.
  • RuudLRuudL Posts: 227
    One important thing is the order in which the startup process sees the extensions. It should first see the original Storyboard - contained within the 3DView extension - and then at a later moment the noStoryboard. The COMserver-entry of the original Storyboard should then be replaced with the noStoryboard data.
    The best place to install the noStoryboard is in the Extension-folder itself, not in a subfolder of the Extension-folder. Unless it is certain that startup will see that subfolder after the 3DView extension.
    Does windows have a different file ordering (ascending/descendig)? If so renaming the noStoryboard to lets say 1noStoryboard might work.
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited October 2021
    You were right. Renaming it did the trick.
    I send you the Window build via PM
    Post edited by Philemo_Carrara on
    Thank you, @Philemo_Carrara
    The Windows version is now also available at my sourceforge page (https://sourceforge.net/projects/carrara-plug-ins-adventures/files/)!
  • HeadwaxHeadwax Posts: 10,456
    great news thanks!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,433
    it works yes
  • StezzaStezza Posts: 8,857
    edited October 2021
    confirming Wendy's comment about Phil's comment re RuudL's comment
    It's gonnnnne cool
    649 x 495 - 95K
    Post edited by Stezza on
