G 8.1 Female does not have textures (SOLVED)
squirtsquirt Posts: 204
edited October 2021 in Daz Studio Discussion
Hello Daz Gurus:
I recently purchased the Victoria 8.1..   I downloaded it and then tried to put it into the render room.  I got a warning that it needed to update Starter Essentials which it did.
However.  When the figure showed up it was without any sort of skin textures..  Making it look like a marble statue.  It is rigged and all of the dials work, it's just missing all of the textures.  I also bought Raw Art's Pearlette and it does the same exact thing.  So both figures are missing their automatic textures.  When you try to apply the textures to them nothing happens.   Does anyone know what went wrong and how to fix this problem?
I've included a screen shot so that you all can see what I mean.
(SOLVED, what brought by my Iray Render Engine was a udate of my drivers.. Who would have thought?  But Emma with DAZ Tech support suggested it and it worked!)
Thank you all very much for your help!  It was much appreciated!
Post edited by squirt on
  • PetraPetra Posts: 1,157
    Are you in Iray preview?
    I had that and then realised I was in Filament preview.
  • squirtsquirt Posts: 204
    edited October 2021
    Hello Daz Gurus:
    I recently purchased the Victoria 8.1..   I downloaded it via DIM and then tried to put it into the render room.  I got a warning that it needed to update Starter Essentials which it did.
    1311 x 1311 - 603K
    edited October 2021
    I'm definatily in Iray Preview.   I didn't even know that a Filament preview existed.
    I loaded a Victoria 8 into the scene and it came out just fine with all of its initial textures and new ones could be added to it.    But the V8.1 is still pure white. sad
  • felisfelis Posts: 6,504
    What does your log say Help > Troubleshooting > Log?
    edited October 2021
    I'm seeing a lot of Scene Option No Longer Supported messages towards the end of it.
    This is in there too: WARNING iray_optix_prime' scene option is no longer supported.
    Here's even more data from the LOG as it exactly appears:
    2021-10-11 17:16:18.554 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:21.935 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04548 iterations after 139.778s.
    2021-10-11 17:16:21.939 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:24.648 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04638 iterations after 142.491s.
    2021-10-11 17:16:24.658 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:26.812 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04710 iterations after 144.655s.
    2021-10-11 17:16:26.853 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:28.574 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04767 iterations after 146.417s.
    2021-10-11 17:16:28.581 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:29.965 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04812 iterations after 147.808s.
    2021-10-11 17:16:29.969 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:31.090 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04848 iterations after 148.933s.
    2021-10-11 17:16:31.115 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:32.115 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04880 iterations after 149.958s.
    2021-10-11 17:16:32.120 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:33.110 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04911 iterations after 150.953s.
    2021-10-11 17:16:33.115 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:34.064 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04941 iterations after 151.907s.
    2021-10-11 17:16:34.069 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:35.073 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04972 iterations after 152.916s.
    2021-10-11 17:16:35.079 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-10-11 17:16:35.951 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 05000 iterations after 153.794s.
    2021-10-11 17:16:35.951 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Maximum number of samples reached.
    So if you can make heads or tails of that.. You're a far better man than me!
    It was more what does it say regarding loading textures for Victoria?
  • Exactly which version of daz Studio is this - Help>About Daz Studio? It needs to be 4.14.0.2 or later for the new PBRSkin shader, used by Victoria 8.1, to work.
    I just attempted to apply the Iray Skin textures and did a Help/Troubleshoot/Log and this is the data that came up:
    2021-10-11 17:32:23.712 File loaded in 0 min 0.6 sec.
    2021-10-11 17:32:23.712 Loaded file: Victoria 8.1 All Maps.duf
    2021-10-11 17:32:23.966 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2021-10-11 17:32:24.010 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Sevenine HD__Torso_2657_3698' uses MDL JIT compilation.
    2021-10-11 17:32:24.012 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Sevenine HD__Face_2658_3713' uses MDL JIT compilation.
    2021-10-11 17:32:24.022 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Sevenine HD__Lips_2659_3728' uses MDL JIT compilation.
    2021-10-11 17:32:24.024 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Sevenine HD__Ears_265b_3748' uses MDL JIT compilation.
    2021-10-11 17:32:24.026 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Sevenine HD__Legs_265c_3763' uses MDL JIT compilation.
    ETC...
    edited October 2021
    I'm using the 4.12 version....
    How do I update to the 4.14.0.2 version?
    Have you updated the Default Resources for DS4.15 for the new shader?
    No, and I'm not even sure how to do that.  Sorry. sad
    Nevermind, you were using an older version...
    You need to update your DS, which method have you used to install DS and your assets?
    edited October 2021
     I've been using DIM to install pretty much everything though.  My manual stuff is in a zip file on my desktop which usually contains my Renderosity stuff.
    I suppose I should look for a method of udated my 3.12 to 3.15.  I found a good video on Youtube and am doing it now.
    It looks like I need to do a udate from 4.12 to the latest version.
    I can see the Daz 4.15 update now.  Looks like I need to do that update so will do it!
  • Merged threads, please don't post the same topic in multiple forums.
    Understood, but I could find no way to Delete the first one which I put in the Commons.
    edited October 2021
    I'm stuck at the infamous  Photoshop 3D Bridge for Daz Studio 4.15 + (Win 64bit)....   It wants me to define a path.
    You wouldn't happen to know how I could figure out the right path would you?
    edited October 2021
    I updated Daz 4.12 to 4.15..  It looks drastically different now.
    I've included a Screenshot to show you what it looks like now.   Does this look right?
    Also, when I look at the version it still says 4.12...  Something is crazy weird here.
    1311 x 1311 - 420K
  • Daz Studio was running when you installed, probably just in the background as it cleared up. Make sure it is closed in Task Manager's list of processes, then uninstal and reinstall.
    You mean, totally uninstall???
    How does one totally uninstall DAZ?
  • Uninstall the application, and the Dynamic Clothing Control plug-in if you have that, then reinstall - everything else can be left alone.
  • chris-2599934chris-2599934 Posts: 1,975
    edited October 2021
    Fire up DIM, find Daz Studio in the Installed tab, click "Uninstall." It should then turn up in your "Ready to Download" tab if you refresh. Make sure Daz isn't running while you do this.
    Post edited by chris-2599934 on
    Yep, did that but it didn't solve the problem.  What did is was updating my GeForce Drivers..     But thanks a lot ofr the suggestion Chris and everyone else who helped me.  You all are the BEST!!!!
