Genesis with facial shape that affects eyelashes causes distortion...?
Sphinx Magoo
I've run across an issue where there are some shapes for Genesis which affect the eyelashes. If I then apply clothing which is conformed around the figure's eyes (like goggles, helmets, or glasses), that clothing around the eyes gets distorted. I've had this problem with a couple of different morphs, but more recently with the Jason shape (http://www.daz3d.com/jason-for-genesis-character).
Is there an adjustment morph I don't know about which might make the clothing go back to normal?
Thanks!
Make sure you have "Show Hidden Parameters" enabled in the Parameters pane, then you should see the autofollow morphs in the clothing and can turn off the offending one.
