Looking for a sun visor...
in The Commons
I've been unsuccessful in my searches and to avoid possibly reinventing the wheel, I'm wondering if anyone is aware of a conforming sun visor, prefereably G8F (G8M or G3* could also work)?
Example attached.
Thanks in advance!
There must be others available, but the only one I'm familiar with is part of this beach volleyball clothing set.
Unfortunately it's for G2F. I know it works fine on G3F but I haven't tried it on G8 yet.
Edit: Below is a sample with that visor on G8F. Please ignore the shadow noise that remains, just a quick render.
Note that you'll have to do some fiddling to fit properly with whatever hair you're using, moving & scaling the visor as required. Or use one of the Hat-Hair-Helper type products in the store to quish it down.
Hope this helps!
Good find. From the promos I prefer Fefecoolyellow's visor. It sits lower and sticks out forward which helps with hair fitting issue.
Thank you very much to both of you!
Thank you, I will get both.
Anything new ?
Edit:
I also found dForce Beach Sport Suit for Genesis 8 and 8.1F by lilflame
