Sanjay 8 Will Not Download
TJohn
I've tried DIM, "download failed".
I've tried downloading the zip file from the Product Library here at Daz, I get a browser page with this message:
"code": "expired_auth_token",
"message": "",
"status": 401
The problem seems to be with the file itself.
Help is appreciated, thanks in advance.
Seems like Daz has a general download problem https://www.daz3d.com/forums/discussion/524986/dim-won-t-download-new-purchases#latest
Thanks.
Yes, this has been reported. I bleive, if you need to isntall now, that Daz Connect (which is using a different source) is still working.
FYI, DAZ Connect is reportedly not working either.
Did you try it or did someone else say it?
Right here:
https://www.daz3d.com/forums/discussion/524981/suddenly-unable-to-install-any-content
Closing this thread as there are others.
Just a note, so as not to leave it hanging - Connect is working for me (that is, installing through Daz Studio - Daz Central is affected and I typed the wrong name earlier so it may be that the other report meant Central).
