Looking for a lift gate
kaotkbliss
I could have sworn the ambush alley apocalypse add on (http://www.daz3d.com/ambush-apocalypse-wasteland-environment-props) had this object. (Just the gate part, not the building) But when I just looked to make sure, I didn't see it in there :(
I'm looking for something along the lines of the attached pic but I've yet to find one (here or on sharecg) :(
Post edited by kaotkbliss on
Not exactly the same, but.......
http://www.daz3d.com/the-checkpoint
Thank you, that's something to keep in mind as I might be able to edit out all the walls and such I don't want with Hexagon... It would take some work, but might be doable.
Here are two free ones of similar design. You must be a registered member for both sites. Registration is free:
At Renderosity
http://www.renderosity.com/mod/freestuff/?item_id=65575
At Sharecg
http://www.sharecg.com/v/9602/browse/11/Poser/Axis-Checkpoint
Thank you so much Dollygirl, those will work perfectly. A little bit of retexturing on the ShareCG checkpoint one and it will fit in exactly where I need it :)
