RSSY Iray to 3DL Kit script not working.
I'm having no luck at all with this product. No matter where I put the script and shaders the script never works. I've put it in my main library, given them their own content library on both my external drive and on my c drive (not at the same time). Nothing works. None of the shaders apply. I can apply them manually so the shaders themselves are not broken. I have downloaded it manually and through DIM, it doesn't make any difference. Any help provided would be appreciated.
  • TotteTotte Posts: 14,754
    Do you run the script and follow the three steps?
    1 - load scene items
    2 - assign shaders and change those failing
    3 - Apply
    I use it all the time and it never fails
  • LorraineLorraine Posts: 907
    3 - Apply
    yes, I do.
