Gymnastics Parallel Bars: Prop and Poses
richardandtracy
Onesixthwarrior over at Renderosity asked if I could do something about a model of a set of parallel bars.
So, after spending a fair bit of time calculating the flex for different load positions using basic engineering formulae and creating 10 different morphs, got the model below. Please read the 'Readme' file to get an idea of how to use the morphs. There are two height morphs and a width morph.
If you want close to total realism on the bend of the bars, it's possible. The bend morphs are at 100% when 100kg (220lb) is applied to the morph load point. If an 80kg (176 lb) gymnast is supporting their weight on two hands in the middle of the two bars, the 'Bend 3' morphs are set to 40kg/40% at each bar. If the same 80 kg gymnast is supported by two hands on the same bar, each hand position bend morph will be 40kg/40%. If the gymnast is supported on 1 hand, the bend morph will be 80kg/80%. There are no bends induced when the gymnast is immediately above a support. Due to hysteresis (energy absorption) in the bars, when the gymnast unloads a bent bar, it's unlikely to spring back more than 30% past the un-deformed position, and -10% to -12% is a reasonable recoil morph range after a +40% bend has been applied.
I modelled the bars with a MASSIVE character in mind, and realized too late to change it that they are probably too high for normal gymnasts. So, can I suggest you try the bars with the 'Lower' morph set to 50% or more, and adjust the 'Higher' morph to set the bars to the exact height you want. The bar top height is 204cm (6'8") by default - see what I mean about too high. The 'Lower' morph is 1%=1cm lower. The 'Higher' morph is more of a 'fine adjustment' morph at 1% = 1mm/ 100% = 10cm.
I hope it's useful to someone.
Regards,
Richard.
The first set of poses for the bars are below. No mirror poses, as the poses are pretty symmetrical. There are corresponding poses to set the height and flex on the bars too.
Regards,
Richard.
The second (and last planned) set of poses for the bars are below.
Regards,
Richard.
I love that you've included the flex morphs for the bars! It's small details like that that can make or break an image.
