Everytime I move/translate an object or body part, the whole camera pans instead.
For some reason, whenever I select and drag an object or body part, I can't move them. It instead moves the camera like it is panning. I'm using version 15.0.
Whhich tool are you using? What is its selection mode (set in the Tool Settings pane)? Are you selecting and then using the gizmo, or are you clicking on the body part itself and then dragging that as a single action?
It's like that in general for tools. The selection mode is set to Node.
Like for example, I use the Translate Tool and when I move the gizmo, it moves the camera. If I use the Active Pose Tool and move a body part, it moves the camera as well.
I also would like to note that this also happens with every icon in the viewport. It seems I can't click even the cube with "front", "left", etc. labels to change the view, as well as the perspective view drop down box. The program somehow recognizes it as a dragging input and then when I move my mouse, it moves the camera.
