Cross Generation UV
tititlemot
Hi guys,
I'd like to ask, is it possible to apply M4-base figure's UV or MAT, such as Adham's or Tyrese's UV or MAT on my G2M figure?
I appreciate every answer & respond
Thank you
Regards,
king_of_kerb
The original Genesis model is UV mapped to take skins from V4, M4 and The Kids 4 as well as the Base Genesis model itself.
You would need this to apply M4 skins to Genesis 2 Male : http://www.daz3d.com/michael-4-for-genesis-2-male
There may be other solutions too, so wait to see what others suggest.
Well noted, JimmyC_2009. Thank you very much.
The only other way, that I can think of, is by using map transfer. Michael 4 for Genesis 2 Male is my product, by the way, but I don't mind sharing other methods with anyone.
If you are only wanting to use one or two M4 textures, then using Map Transfer might be a good solution for you. What you would do is apply the M4 texture to Genesis (as stated before, the uvs for M4 are included for Genesis), then use Map Transfer to convert the texture to M5. The new textures would then fit Genesis 2 Male because he already includes the M5 uv maps.
I find map transfer to be tedious and it never works for me, the converted maps still look better on the model it was meant for
