Hair and Elf ears, how do I stop this? (Problem solved)
Malandar
Okay, I bought this hair and it has this problem that I hate about hair because it is a royal PITA. How do I stop this from happening or how to i make it stop either one, I seem to remember there being a solution to it from years ago when I had the problem, but damned if I can remember what it is?
To be 100% clear the problem I am talking about is that the hair is conforming to her ear point.
Post edited by Malandar on
It's character ears morph under "hidden" in either properties or shaping tab. If you switch Daz to showing hidden properties for the hair item and then dial this morph back to 0 it will go away.
When clothing and hair are fitted to the character Daz is automatically copying morphs from the character. They all land in the hidden morphs properties.
Hmm, how do I do that? I have been goofing with it for about 5 minutes now and can't find it, Thanks for the quick reply BTW.
Right-click on the properties tab and pick "show hidden properties", then check all the now-showing hidden morphs for the hair item. Or check the "currently used" values for the hair because the character ear morph will be greater than 0.
Thanks. I have a bad memory, and I remembered something about hidden morphs, but I could not figure out how to do it again, and then another problem I was having is I was looking in the shaping tab, but for some reason, the morph does not show up in the shaping tab, even when show hidden is checked, not sure why, but it was there when I looked in the parameters tab... Thanks again, you saved me a lot of frustration.
