Coupon code problem
I keep getting coupon code not valid on the blink sale.
THe header is confusing because it sounds as if as a pc+member, you can get the discount even without a new release in the cart. But I have tried both with and without and it says coupon code invalid.
  • The PC+ Cupon worked for me when I used it over an hour or so ago. Did you include only three items from that selection (clicking on the banner shows the selection of items the cupon can be applied on)?
  • I only wanted one. I tried both coupons and neither worked.
  • I should be clear, I didn't take 3 items from the list. I took just one and a new release (though at first I thought I didn't need a new release for the pc+ coupon). Nothing works.
  • davesodaveso Posts: 8,264
    its screwed up. if you put in 3 items from the list, it works ... not 1, or 2, as it says, but 3.
  • THanks I tried adding 3 and it worked. Turned out better for me in the long run.
