How do I unhide all objects at once in the Scene Pane?
Grr...I have most but not all of my objects in my Scene Pane hierarchy hidden. How do I unhide everything at one time without having to do it all manually?
Select everything, then go to the Parameters pane and set Visible to On.
Thanks. I can't believe there is actually a "workflow" for something that should be so simple as a hotkey in my opinion. For the record, here is the workflow:
losing me, Guys. I can select everything but Visible shows only after I click on Display. But Visible is already set to On even though selected items remain invisible.
Click the lined button at top-left of the parameters pane and make sure that Preferences>Consolidate properties is checked and Preferences>Display Separate Items is unchecked, then the Visible button should show "Mutliple," since you have a mix of visible and hidden items, click the button (twice if necessary) to get them all visible.
Checked-Show Hidden Properties,Consolidate Properties. Unchecked-Persistent Group Expansion, Display Separate Items. Visible- On. Still bunch of items invisible. Clicked Visible-on/off few times, no change
