Where do I find the templates or image files for genesis so I can paint her toes.
dannybrightonline
Hello again,
I really want to give my avatars pretty feet. Pleas tell me what an image layer is..and where can i find it. The kind administrator gentleman told me about it but Im such a noob...sigh. Please make it simple as I don't know much about editing images but will do my best.
Thank you for your kind help
Danny Bright
Is this for Genesis 2 Female?
Load the figure, use the Surface Selection Tool (Alt+Shift+M) click on the toenails, and they should appear with an outline around them.
Then go to the Surfaces pane, Toenails should now be selected. Select the Diffuse Color area in the Surfaces Pane, click on the little triangular down arrow, and select 'None'. Now you can make the toenails any colour that you like.
There are other ways, but the above way is the easiest in my opinion.
You can find templates here, with seam guides to make it easier to find the right parts, if you want to design your own Nail polish. However you will need a paint program which supports working with layers.
http://www.snowsultan.com/3.html
