New one for me. Part of the hair doesn't auto-follow.
I've never experienced this before. The morph is part of Zevo's Body Diversity for Genesis 8. The morph itself is BD Proportions Body Scale.
Hair is Vertigo Ponytail for Genesis 8.
When the morph slider is all the way to 100% (making the model smaller) the actual tail fits to the hair. As the slider goes the other direction, the body and hair cap move but the tail doesn't. I couldn't see anything out of the ordinary in the settings either. Does anyone know how to fix it? I did try to reload the hair but that didn't work. I've attached screenshots.
Does anyone have any idea how I can fix this?
  • barbultbarbult Posts: 26,316
    I think that hair tail has bones for posing.
    If the tail is a separate prop, parented to the rest of the hair, it doesn't necessarily autofollow the morphs activated on the figure.
  • RedzRedz Posts: 1,459
    edited September 2021
    The ponytail has a rigidity group to stop it deforming when different shapes are applied. It works great for most shapes, but some body scaling morphs aren't playing nice with the rigidity.  (I don't have your particular one, but it happens with the giant HD scaling morph). A partial fix would be to remove the rigidity group. Select the ponytail, go to geometry editor and choose vertex mode, then right click the rigidity group that shows up and delete it. Best to do this before you apply your morph, otherwise you'll need to go to scene tab and with the hair selected, click the dropdown menu and click assets - clear generated morphs. I say partial fix, as without the rigidity, the ponytail may be a little distorted by your morph.
    Post edited by Redz on
    Edited - thought I'd found the reason but it's not working consistently
    It does have the ability to tweak it. However, the tweaks deform it because I have to disable limits.
    I'll check that to see. I thought it was one mesh though.
