Nana's clothes don't fit
I'm trying to use Nana's clothing pack:
https://www.daz3d.com/nana-s-clothing-pack-1-the-basics
But weirdly, the clothes don't seem to fit. They look fine when I load them, but when I conform them, there's severe poke-through.
I have the same problem with the "Nature Defender" clothing pack.
The bathing suit that comes with Nana fits correctly.
I'm using Poser 11, but I believe these products were created for Poser, so that shouldn't be an issue.
  • TaozTaoz Posts: 10,280
    Working OK in DS it seems, despite it isn't listed under Compatible Software.  A little armpit poke-through with certain poses, but a smoothing modifier fixes that.  Here rendered in 3DL default setup.
    801 x 930 - 326K
  • I've found a solution. Figure -> Copy Joint Zones From fixes it.
    Very odd. Never had a problem like this with DAZ products before.
  • McGyverMcGyver Posts: 7,085
    I forgot that was a toon figure... I was thinking of some Genesis granny character with droopy britches.
    LOL. I get it, but "Nana" is used as a girl's name in Japan.
    And there's Nana Visitor, AKA Kira Nerys from Star Trek. She pronounces her name Na-NAH.
    Still find it very weird that the clothing in the clothing packs doesn't fit, but the swimsuit that comes with the figure does.
  • I pulled out my old Poser 11 to test and can confirm that the body suit for instance doesn't work just by conforming. The products were created for an older version of Poser, and IIRC Poser changed the way things conform in newer versions. The bodysuit also works for me when I tick "Match end points" on the properties tab of the clothing.
    (I might have missed something as I haven't used Poser for quite some time.)
